2001 Prairie 400 4x4 - Neutral Light
Old May 7, 2009 | 12:31 PM
bog crawler's Avatar
Default 2001 Prairie 400 4x4 - Neutral Light
I'm hoping one of you have experience with the problem I'm having. The neutral light will not work. I have tested the wiring to the bulb and both wires are hot. I have checked the relay in the battery box which contains a blue, green, and two black wires. The blue and green here are hot. The 4 wheeler will start manually and run fine, it just won't detect neutral and allow the electric start to function.
Any ideas?
Old May 7, 2009 | 03:13 PM
Hayashi's Avatar
Check the neutral switch on the engine. The switch is not sending a signal. No signal means no N light and no electric starting. Sometimes cleaning of the switch is all needed to make a positive contact.
ScopeZ_
Jul 28, 2015 01:44 AM
Schneider
Jul 24, 2015 05:05 PM
JoAnnS
Jul 23, 2015 02:18 PM
coolguy420
Jul 10, 2015 01:17 AM
coolguy420
Jul 9, 2015 09:54 PM
