seal in rear drive shaft
Old Oct 27, 2009 | 10:04 AM
vincentdrivingfool's Avatar
Default seal in rear drive shaft
Just in process of puttin in new swinarm bearings in my 05 650 bf. Not an easy job, but getting through it. Had the driveshaft out of where it slides into the rearend and noticed that it is leaking rear fluid. Isupect that this is so due to having the shaft out. SO does the shaft slide into a seal? Any info much appreceiated? thaks Ren.
Old Oct 27, 2009 | 03:10 PM
Hayashi's Avatar
Leaking rear fluid?
Did you mean out of rear hole in the engine? If yes, that's engine oil and of course it would leak without the shaft in there.
Old Oct 28, 2009 | 11:34 AM
KMKjr's Avatar
Replace the seal anyway if you have the shaft out, good preventive maintenance.
Old Oct 29, 2009 | 09:54 AM
Hayashi's Avatar
When you reinstall the shaft into the seal, put lots of grease in between and make sure the tension spring does not pop out from the seal.
KimSJoh
14
Jul 18, 2015 07:20 PM
joeyupton
Jul 14, 2015 11:51 AM
clsharky
Jul 13, 2015 02:07 PM
tporath
Jul 11, 2015 12:31 PM
rcappie4
Jul 10, 2015 04:54 PM
