2002 Prairie 400 has me stumped
Old Nov 4, 2009 | 10:16 AM
yamaha45085's Avatar
Default 2002 Prairie 400 has me stumped
I have this 2002 Kawasaki Prairie 400 4x4 that I cannot figure out the problem. It starts and idles fine. will rev up in neutral. but when in high or low gear doesn't have all its power. It seems like low 20 MPH is all its got. I checked vavle clearances they are good, the belt looks good, the carb is clean, float height is 17mm which is kawis spec. I tried to richen it with the choke and leaning it out taking off the air filter lid and it doesn't make a difference, the brakes are not sticking, the compression is about 100 psi, I even put a tach on it and it revs up to 7-8 thousand RPM (but kind of slowly). I need to get this atv done a.s.a.p if anyone has any input at all feel free to speak up and it will be greatly appreciated
Thanks
Old Nov 4, 2009 | 11:14 AM
TheModfather's Avatar
Have you done a compression check on the bike? Sounds like you might have a flat cam.
edit: I need to read - comprehend - reply.
Sorry about that.
Old Nov 4, 2009 | 11:52 AM
checked the compression again and it has 105 psi
Old Nov 4, 2009 | 12:08 PM
im going to do a leak down test on it next
Old Nov 4, 2009 | 02:40 PM
okay I did the leak down test and there are no leaks that I can find. I have no idea is there any kind of rev limiter on this that could cause this?
Old Nov 4, 2009 | 10:31 PM
0010's Avatar
Have you checked the exhaust system? If partially plugged, that could account for the speed at idle but slugishness under load.
Old Nov 8, 2009 | 04:08 PM
I kind of thought that too but the exhaust seems to flow just fine. I am still stumped on this quad it just does not have all of it power???????????????????
Old Oct 29, 2019 | 06:39 PM
Robert Cartwright's Avatar
Default Rev problem
Did you figure out problem I have same issue with my360 prairie
Old Oct 29, 2019 | 07:48 PM
Kymco 450i's Avatar
I would still check exhast flow, a temporary removal of muffler and see if there is a difference. Check intake maniifold for sucking air in craxks or bad gaskets. Remove cover and see if cvt system is working correctly. Watch clutches to be sure both are working in unision. Let us know what you find.
Old Oct 31, 2019 | 05:45 AM
DoctorQuad's Avatar
Is there a hissing after it shuts off? might be like the comment above said, it shoulds like the engine is having trouble "breathing" and getting backlogged
95wolv
Sep 27, 2024 12:00 PM
ReconBayou
Oct 31, 2022 05:37 PM
ReconBayou
Oct 16, 2019 02:24 AM
hueby
Nov 6, 2015 11:34 AM
