99 Prairie 400- Will not idle
Old 12-02-2009, 03:25 PM
polarisbear500's Avatar
Default 99 Prairie 400- Will not idle
Hey guys,
I have a 99 Prairie 400 auto. and it sat up for a few months. i pulled it out and it will not idle if i turn the choke off. i rode it for a while to get it warm and still it will not idle.
i drained the old fuel and put new 93 octane in it with carb. cleaner. Checked the plug and it is good. it runs great at half choke, but any below that, it dies. i even turned the idle screw all the way up and it still will not idle. what do i do now??? thanks
Old 12-08-2009, 03:10 PM
Hayashi's Avatar
Clean out the clogged pilot jet in the carb.
Old 12-10-2009, 03:09 PM
log_dogg2007's Avatar
i second the above answer, you can thank our cheap made expensive gas of todays time for that.
Old 01-07-2010, 12:57 PM
Valverde's Avatar
Guys I had the same problem and did what you said, it improved but I took ALL of the jets out and think I have an adjustment issue with the AIR needle jet toward the front of the carb. I didnt check the setting prior to taking it out, so I put it back in two full turns from being completely screwed in tight, is this correct? It runs better on choke still and wont idle unless I keep tweaking the throttle with choke off. Thanks!
Old 01-07-2010, 01:59 PM
Valverde's Avatar
I screwed the air needle jet all the way in and no change. It runs GREAT on choke, but wont idle when the choke is off and it backfires alot with the choke off and I am keeping the throttle on. I am running lucas fuel treatment thru it along with shell 93 octane. Any help or suggestions would be grealy appreciated.
Old 01-09-2010, 02:07 PM
Valverde's Avatar
it will not even begin to idle off of choke.
I thoroughly cleaned the carb and all the jets.
On choke it idles but smokes alot, blue smoke
Off choke, lite throttle, no smoke, backfires when you let off, no smoke.
What could I be missing?
fyi...I rebuilt the on/off valve under the tank with new gaskets as well.
I thought backfires were due to excessive burning in the exhaust?
Any help or suggestions would be greatly appreciated.
Thanks
Old 03-07-2011, 09:08 PM
fpdhdmc's Avatar
2001 prairie 400 4x4 auto same prob needed choke to idle. read this dropped carb cleaned pilot jet (it was clogged) cleaned rest of carb quick, runs like a new machine. thanks to all
franklyme
10-21-2016 07:18 PM
Nosniborpapa
09-12-2015 05:54 PM
PrairieDog126
09-12-2015 05:23 PM
Minimod
09-10-2015 09:20 PM
Minimod
09-10-2015 08:03 AM
Quick Reply: 99 Prairie 400- Will not idle
