kfx 700 problems
i have kawasaki kfx 700 v twin that acts like it is running out of gas at full throttle and it spits and sputters and then it dies does anyone no what could be wrong with it please tell me
Could be a number of things..Try doing a tune up..new plugs, air filter, drain gas and put fresh gas in it. If it is something electrical, then I am no help with suggestions on that! Have you ever had the valves adjusted?? Maybe they have fallen out of adjustment. Dual carbs might need to be syncronized as well. Does it start ok and idle ok?? Hyashi is good with this kind of stuff, maybe he will chime in on this. These are only a few things that I would check as I am no motor tech but maybe this will give you some ideas to look at....Good Luck!
