Why is my front differential fluid brown?
Old May 20, 2010 | 07:54 AM
snowguy's Avatar
Default Why is my front differential fluid brown?
I changed my front diff fluid in my 05 BF 650 and the fluild was brown, not milky like it had water mixed with it. So I put fresh oil, Mobil 1 10W-40, in it, ran it around came back and changed it again thinking I would flush it out and the fluid came our just as brown as before in just a short ride. Is this normal? What is causing the fluid to turn color so quickly?
Old Jun 5, 2010 | 11:34 AM
snowguy's Avatar
I called my dealer and he said that as long as the fluild wasn't milky like it had water in it don't worry about it. He couldn't explain why the fluild was brown though, seems like there must be some explination, must have something to do with the metal or coating that is on the gears and other moving parts in the housing.
Old Jun 12, 2010 | 01:17 PM
Howmon's Avatar
Is that the recommended Oil for your differential? Thought they all used 80W gear oil.
Old Jun 12, 2010 | 01:49 PM
snowguy's Avatar
No, motor oil is the right stuff, the only difference is the dealer said he uses conventional oil. The oil is the same color as whatever material the gears are made, or maybe it's a coating that the gears are plated with. This is what I could see looking through the drain plug. As he told me as long as it wasn't milky or had metal in it not to worry.
robert301972robert
Aug 30, 2015 11:34 AM
ScopeZ_
Jul 28, 2015 01:44 AM
NatePerz
Jul 27, 2015 03:27 AM
Derek Allen
Jul 22, 2015 09:25 PM
rcappie4
Jul 10, 2015 04:54 PM
