2006 KFX 400 wont shift ??
Old Aug 15, 2010 | 01:16 PM
namssom's Avatar
Default 2006 KFX 400 wont shift ??
I have a 2006 kfx 400 quad and it wont shift out of first gear. The shifter seams stuck, the shifter will slide in and out about an inch i dont no if this is normal or not. Please help me out
After checking it out in the daylight, the shift lever pulls out about a half inch, and if u pull it out and shift it will shift into gear, but it moves back in. I dont no anything about these just bought it from a buddy about a month ago,
Old Aug 18, 2010 | 05:12 PM
hillbilly_racer's Avatar
Sounds like the shifter shaft may be broken. This shaft runs completely through the motor to the right side. To access it, you will need to remove the right engine case and the clutch basket.
95wolv
Sep 27, 2024 12:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
patrick.oc123
Sep 16, 2015 03:45 AM
BigCam
Sep 16, 2015 01:53 AM
patrick.oc123
Sep 15, 2015 02:45 PM
