Prairie 650/750 Ignition fit 360???
My belt sensor will not reset even after doing the reset procedure several times. Belt is within tolerance. I heard Dyna makes an ignition that will eliminate the 100 hour mandatory limp mode..but they only make it for the bigger quads.. Any help would be appreciated..
Thanks,
Tim
Thanks,
Tim
I think you are misinformed....
100 hr belt check (steady) light does not cause LIMP home mode. Flashing light does.
What do you mean by changing the "ignition"? Ignition key or igniter?
Ignition key has nothing to do with the belt light. Igniter does.
Bigger quads (650, 750, etc) igniter does not work on 360.
If your 360's belt light does not reset even if you follow the correct procedure, then the belt switch itself needs to be replaced.
Sw00p
09-24-2015 02:50 PM
