Mojve Problems
Old Aug 24, 2011 | 09:46 PM
MudPimp's Avatar
Default Mojve Problems
I recently bought a 89 mojave in rough shape, and not running. The carb was replaced by a different one so im told, and there is no air box. After popstarting it it ran wot, and pumping out a oil-water mixture from what looks to be the crankcase vent. I originally thought that it was maybe the head gasket, but its not leaking for the head. the oil is very brown and watered down. Any help with finding out what is making it pump this liquid and running wot all the time?
Thanks
MP
Old Aug 25, 2011 | 09:13 AM
Hayashi's Avatar
Watered down oil is not by water but by fuel.
When oil gets mixed with fuel, it looks like watered down.
When oil gets mixed with water, it looks like milk shake.
Old Aug 25, 2011 | 12:21 PM
MudPimp's Avatar
Thats what it looked like, a big brown milkshake. How would fuel get into the crankcase?
Old Aug 25, 2011 | 04:11 PM
Hayashi's Avatar
Leaking float valve in the carb bowl would let fuel flow into the cylinder and then into the crankcase.
Old Aug 25, 2011 | 06:48 PM
MudPimp's Avatar
What would cause it to pump out of the crankcase vent?
Old Aug 26, 2011 | 09:49 AM
Hayashi's Avatar
Exessive crankcase pressure.
As the crankcase oil level rises because of incoming overflowing fuel from carb, the total volume (oil & fuel mixed) increases. When engine is running the crankcase can't handle that much liqud volume and some would get pump out of there via the vent line.
You need to fix your carb leaking fuel into engine.
Also, need to check piston rings for proper sealing.
Old Aug 26, 2011 | 12:09 PM
MudPimp's Avatar
Wow, if that works, I would have never guessed that was the problem. Do you think that would cause it to run wot?
Old Aug 27, 2011 | 06:20 PM
kyleag89's Avatar
If I were you I would check EBAY for the proper carb and intake set-up and start from there. If someone replaced the carb with a different one than get rid of it!
Old Sep 2, 2011 | 07:15 PM
MudPimp's Avatar
There is a different carb on there, a bigger one I believe, the guy i bought it from said he has the stock one but can't find it.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
