carb help
Old Mar 29, 2013 | 09:28 AM
  #21
MrSummit's Avatar
Item # 16017 in the parts diagram. The second piece above the main jet. Must be installed prior to installing main jet holder. Easily forgotton/lost or installed from the top when removing jet holder and rotating carb during cleaning.
https://www.kawasakiepc.com/SystemSe...TOKEN=62503134
Old Mar 30, 2013 | 07:11 PM
  #22
texakaw's Avatar
Yes that's the needle jet I was talking about,its in carb,,,
Old Mar 31, 2013 | 12:12 PM
  #23
dblbassdruMer's Avatar
i usually put 2 washers under my needle my lakota runs fine now i too was having that same problem try putting two or more (2 to start)washers under the needle to raise it up
Old Mar 31, 2013 | 05:28 PM
  #24
texakaw's Avatar
one more question,,when I took carb apart first time the diaphragm on pump plunger on side of bowl was torn,I didn't worry about I don't use plunger anyway.would this cause my problem?
Old Apr 3, 2013 | 11:02 PM
  #25
Ride_TL's Avatar
When dealing with carbs every small part makes a difference, Even a stretched diaphragm can cause problems, Replace what you know is wrong or you will think about it going wrong when you ride and it sucks to have a 2$ part you know is bad leave you stranded somewhere.
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
