Kaw. 650 carb. problens.
Old Dec 16, 2013 | 11:03 PM
Hayashi's Avatar
Originally Posted by papa hogg scoot
Is atv belt light on?
If the light was on, I would think the dealer would have done something about it when they had it for the carb work. Well, that's my guess.
Old Dec 19, 2013 | 05:35 PM
bodatiouskid's Avatar
No belt light.Only light that comes up is trans. light(RNHL)
Old Dec 19, 2013 | 07:19 PM
papa hogg scoot's Avatar
Loved
Community Favorite
Is batt still good Ino you said new..just asking? is atv charging ok...? If not charging then this could cause ignition to misfire{ an real hard choppy miss}Is brake light staying on?
Old Dec 20, 2013 | 05:08 PM
shawn30's Avatar
bodatiouskid, you might check out the known Prairie issues on kawieriders. I've seen many people say the popping is something the Prairie does, but I've seen just as many people say they got it to run great. I've got an 03 and it doesn't pop up through the carb, but I think Kawasaki made some changes between 02 and 03 to the carbs.
Old Jan 16, 2014 | 07:00 PM
  #15
Thanks,there has to be something that can be done.If all Kawi's ran like that no one would buy them.
Old Jan 20, 2014 | 05:32 PM
  #16
Angry
Originally Posted by Hayashi
Manufacturers and (some) dealers don't want to mess with the EPA related parts - that's OK only if the machine is running correctly. It's not in your case. Sometimes you have to take it in your own hands.
So,what can I do?Adjust carbs like was told,or is it other things that can be done?
Old Jan 21, 2014 | 08:39 PM
  #17
vbalz's Avatar
are you running with the air box lid on ?
have you checked to see if the carbs slides are pulsating, when the engine is running?
have you checked for exhaust leaks?
if your answers is yes....you more than likely still have dirty PILOT jets try recleaning
Old Jan 22, 2014 | 07:12 AM
  #18
Question
Airbox lid on.No exhaust leaks.Haven't checked carb slides(?)
Old Jan 22, 2014 | 07:59 PM
  #19
Loved
Community Favorite
Well yes you right dealer should have BUT never know thats why I asked.
Old Jan 22, 2014 | 08:05 PM
  #20
Loved
Community Favorite
Just went back a reread all comment an I noticed in your first post you said dealer replaced batt!!!!Is atv charging ok If charging rate is wrong this could cause ignition to fail[weak] an cause an cough or popped back thru carbs just an ideal
