Kaw. 650 carb. problens.
Old Jan 23, 2014 | 08:34 PM
  #21
vbalz's Avatar
Originally Posted by bodatiouskid
Airbox lid on.No exhaust leaks.Haven't checked carb slides(?)
remove the air box lid....remove the air cleaner
start the engine ( it will run like crap.but should still run)
look down into the carbs with it running, both carb slides should be
pulsating at the same rate.
if that's ok...
pull the pilots jets out of both carbs and clean
if you don't know where the pilot jets are,watch this vid
if that doesn't cure it ..adjust the valves
I've had similar problems in the past with these kawie v-twins..good luck
Old Apr 6, 2014 | 02:16 PM
  #22
bodatiouskid's Avatar
Originally Posted by vbalz
are you running with the air box lid on ?
have you checked to see if the carbs slides are pulsating, when the engine is running?
have you checked for exhaust leaks?
if your answers is yes....you more than likely still have dirty PILOT jets try recleaning
Front slide pulsating,rear stays still until reving up or popping.Not popping through front carb.
Old Apr 7, 2014 | 02:33 PM
  #23
papa hogg scoot's Avatar
Loved
Community Favorite
sounds like front cylinder not running or hitting....should be still until revved up.
Old Apr 7, 2014 | 05:01 PM
  #24
Unhappy
Was just told by vbalz they both should be pulsating.
Back carb popping back,front carb. running ok.
Old Aug 22, 2014 | 08:56 AM
  #25
n185h's Avatar
have a 650 with the same carb problem - does anyone know someone in this area ( zip 28663) Piney Creek NC - who can fix the carbs for us. had a small engine guy work on them and sounds like one screw wasnt replaced or fell out on the way home - but may need new carb
wendal
Oct 31, 2017 03:31 AM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Sassinm1
Sep 30, 2015 04:23 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
