kfx400 dies while riding
Old Dec 15, 2013 | 06:05 PM
kfx400riderprobs.'s Avatar
Default kfx400 dies while riding
I have a 2004 kfx 400 it will die while riding it. I will try to start it and the battery will be dead. I charge the battery and it will fire right up.
Old Dec 16, 2013 | 09:54 AM
Zrock's Avatar
Super Quad Patrol
how old is the battery?
Old Dec 18, 2013 | 05:50 PM
Default Kfx400 dies while riding
the battery is about 2 years old
Old Dec 18, 2013 | 09:36 PM
Hayashi's Avatar
What is the battery voltage when engine is running?
It should be 13+ VDC at idle rpm and go up to max about 14.5 VDC at higher rpm.
If not, your charging system needs to be checked.
Old May 26, 2014 | 11:16 PM
ColetrainX21's Avatar
Mine did the same thing and it was blowing fuses on the solenoid. I could put a new fuse in and push start it and it would run, but then it stopped doing that and blowing fuses, now it just isn't getting spark PERIOD.
I have replaced everything electronic on it except for the wiring harness and the starter button. The button works fins but where the problem is,I have NO IDEA.
Frisky2050
Apr 9, 2020 11:19 AM
sara durrant
Jul 6, 2015 05:32 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
Big600twin
Jun 10, 2015 03:01 PM
