2006 BF 650i
Old 02-26-2014, 11:58 AM
windsor396's Avatar
Default 2006 BF 650i
I am hearing alot of noise coming from the heads. I have tried to adjust the valves but it seemed to have gotten worse. It does sound like valves and I just wanted to know if there is a common problem with the valves, timing chains on these engines?
I love the independent rear on this so I want to repair this machine. Should I just pull the heads and check replace timing chains? I really think the valves are not seating properly. It has 3600 miles on it and has been an awesome machine.
Old 03-05-2014, 02:47 AM
TEXASBAGMAN's Avatar
2005 AND 2006 KAWI 650,700,750-SRA,I all have timing chains that fail early. hAD PROBLEMS WITH THE SEALS LEAKING AS WELL. chains COST $125-150. STEALERSHIP AS MUCH AS $850.00 TO CHANGE THEM. 2 TIMING, 1 INTERMIDIATE, 1 OIL PUMP CHAIN TO CHANGE.
ltrmc02
08-22-2021 02:34 PM
akguy31
08-31-2019 04:34 AM
clscott84
09-21-2015 10:16 AM
snowolson
08-31-2015 03:51 PM
dwhipper61
08-27-2015 11:01 AM
Quick Reply: 2006 BF 650i
