Need advice on bent frame
Old Aug 2, 2014 | 08:25 PM
Nix377's Avatar
Default Need advice on bent frame
I bought a used 2011 Brute 650 SRA with only 160 miles on it.On my first ride with it a hit a rut super hard and tweaked the frame. It looks like it's bent slightly, right next to the cross brace that's welded behind the front a- arm mounts. The paint chipped off the frame on both sides around the welds, the welds appear to be fine. I took a few quick measurements. I measured from the foot well mount to the a-arm mount and found the left side is about 1/4" shorter than the right. I also took a wheel base measurement and found the left side is 5/8 shorter than the right.
I need some advice....can the frame be straightened or do I need to replace the frame?
It tracks straight while riding and handles normally.
Old Aug 4, 2014 | 10:09 AM
Nix377's Avatar
Attached a coupke of pics. The pic with the arrow is the left side, showing a dimple in the tube.
Attached Thumbnails Need advice on bent frame-bf-left.jpg   Need advice on bent frame-bf-right.jpg
Old Aug 5, 2014 | 02:26 AM
I've no doubt that the frame can be repaired, try a motorcycle shop, they will be used to mending bent frames. However if the machine drives OK as it is, I would leave it alone, but then I'm used to getting big Suzukis in for service and finding the bottom frame rails broken in two (or three). We just weld em up, add gussets and send them back out again.
Old Aug 5, 2014 | 11:16 AM
Nix377's Avatar
Thanks!
I took some measurements last night. It looks like the frame is only off anywhere from 1/8 to 3/16". I'm going to take a closer look at the a-arm tonight.
ultangler
Nov 30, 2024 01:35 AM
Pehter
Oct 3, 2024 11:00 PM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
wrencher82
Sep 28, 2015 10:02 PM
meddy0388
Sep 9, 2015 06:41 AM
