92 bayou 4x4 disassembly issues
Old Mar 28, 2016 | 07:04 PM
The shemdawg's Avatar
Default 92 bayou 4x4 disassembly issues
Howdy all
Gears finally crapped out in my kawi. Ive got the cases disassembled on the bench but cant get the clutch hub off the crank. The manual just says "slide it off" this dont slide off. It looks like its pressed on and im stuck on that now.
I already had the new gears in and was shifting gears on the bench to make sure everythings working and the balancer is hitting the crank now and I cant get a full revolution either way. The balancer gear and the crank gear w the springs have the timing marks lined up. What the hells going on? lol
shem
Old Apr 8, 2016 | 08:17 PM
_smf_'s Avatar
Originally Posted by The shemdawg
Howdy all
shem
Can you get one of those three jaw pullers and pull the clutch off? Check out 400bayoufix.com there is a video on oil pump replacement and he removes clutch in it.
COwen
Aug 1, 2016 07:52 PM
Asaran
Jun 2, 2016 07:24 AM
heavybossman
May 7, 2016 10:46 AM
grangerboy
Mar 29, 2016 10:21 PM
Bubbachunks1
Mar 24, 2016 06:19 PM
