Valve stem size?
Old Dec 8, 2019 | 07:56 PM
Bill Hilly's Avatar
Question Valve stem size?
Anyone know the size of the hole for the valve stem on bayou 220?
Old Dec 9, 2019 | 03:13 AM
Don't know, the Lakota valve guide is 7mm inside diameter with a service limit of 7.08mm, this is quite big for Japanese stuff. I'm sure Hondas etc, are about 5mm. Why the question, now you have it running?
Old Dec 9, 2019 | 01:31 PM
Bill Hilly's Avatar
ive been working on homemade "tire slime" for many years. All the successful formulas required unseating the bead of the tire and adding the goo that way. Was thinking of installing air/water valve stems to allow for larger filler to pass that will clog a standard valve stem.
Old Dec 9, 2019 | 02:50 PM
Kymco 450i's Avatar
Slime does not require breaking the bead, instructions call for removing valve stem core o install slime material, add air without stem valve. This seems to push the material into the tire and cleans the stem. Reinstall the valve stem and air tire as normal, take it for a ride to distribute the slime material. No mention at all about breaking the bead.
Old Dec 9, 2019 | 07:06 PM
Bill Hilly's Avatar
"Slime" is about $25 for one gallon. Mine is less then $5 and works well in the old farm trucks. But it will play hell with the tire balance until it gets sloshed around.
Old Dec 10, 2019 | 03:02 AM
When you mentioned valves I assumed engine valves, so forget the 7mm.
We never use slime. If a tubeless tyre gets a puncture we fit a plug, two min job. If the cut is too big, fit a tube.
Old Dec 11, 2019 | 04:13 PM
Bill Hilly's Avatar
FYi the hole in the rim for the valve stem is 10mm.
nrmarine607
17
Aug 27, 2007 12:36 AM
kaptap
Feb 28, 2006 08:52 PM
ShadyRascal
Nov 4, 2003 07:04 PM
Zorro
Feb 22, 2001 11:01 PM
97warrior
Mar 3, 2000 11:57 AM
