99 Kawasaki Prairie 400 Voltage/rectifier
Hello All
I am trying to diagnose a possible bad regulator/rectifier. I have looked any many videos. But none cover the power and ground wire testing only from Ground to to stator and positive to stator.
This is what I am seeing.
regulator/rectifier
Battery side of connector
2 white with red strip +12v
2 black wires Ground
1 Brown wire
Stator Side
3 yellow.
Tested as fallows
With regulator/rectifier plugged in to the main harness and battery disconnected I tested Continuity from the + white wire from the battery side to ground/frame I have continuity.
With the power side plug disconnected from the regulator/rectifier. I tested Continuity from the + white wire from the battery side to ground/frame its open. as i should be.
testing regulator/rectifier stand alone.
testing with + to - there is continuity
testing from + to each leg there is .5 .5 0
testing in reverse same
in all testing direction
So my assumption is the regulator/rectifier is shorted internally from + to - and there is 1 bad diode
Can some one please confirm or if i,m missing something please speak up.
Thanks
regulator/rectifier
1 Brown wire
Stator Side
3 yellow.
Tested as fallows
Thanks
