KLF220A pulling my hair out, no spark
Old Aug 28, 2023 | 02:23 PM
KW900A's Avatar
Default KLF220A pulling my hair out, no spark
Hey all, new member, I just joined here hoping I can find some help, I’m always happy to help others but this time I’m at a complete loss. I’ll try to explain all this as best I can.
I got this 94 220 Bayou doing some trading, the guy said it had quit running, and they couldn’t figure out what was up so he robbed some parts for another one and this one just sat in his shed. So it has not run in years. It was missing the flywheel rotor with the ring gear. I replaced the stator. The factory pickup ohms out to spec, generates ac current (.6 vac), I have an Amazon and a used oem cdi, the original oem smoked when I hooked up the battery, safety relay and starter relay are new. Neutral safety is working. It will crank with the button. But nothing I have done will get this this to excite the coil. I have an oem and Amazon coil. Neither really ohm within the spec but I’m tired of thinking I’ve found the problem and buying another part, so I’ve just been checking for a pulse at the green wire to the coil. I’ve ohmed the wires, checked voltages, used jumpers to get grounds, and I can’t seem to come up with anything. I have been doing electrical troubleshooting for years but this thing has worn my brain out. I cannot figure out what I am missing. Sorry I know this is long winded but I have spent hours with this and am just about at a loss, I’m sure it’ll be simple but I’m at my wits end… thanks in advance
Old Aug 28, 2023 | 06:42 PM
papa hogg scoot's Avatar
Loved
Community Favorite
Does the stator you put in match the old stator? same amount of bars and windings? is flywheel same brand that came off of this atv?
Old Aug 28, 2023 | 06:44 PM
Loved
Community Favorite
Also if voltage regulator is over changing it can blow other parts
Old Aug 29, 2023 | 02:38 AM
I have found two totally different wiring diagrams on the net, one for DC and one for AC so it is just possible Kawasaki changed from one to t'other. This would throw things wildly out, if you fitted a stator for DC to a machine wired for AC, or the other way round.
Old Sep 9, 2023 | 03:20 PM
Loved
Community Favorite
Did you get issue fixed?
Blastapest2
Jun 26, 2018 01:59 AM
holi66
Aug 6, 2017 12:40 PM
Fasteratv
Mar 9, 2016 03:50 PM
turbowrenchhead
Nov 5, 2014 02:46 PM
f1coop
Sep 30, 2008 06:13 AM
