Problem with clamp on K&N
Old Aug 11, 2001 | 08:10 PM
lightning's Avatar
Ok i just installed my clamp on on my mojave and 1 problem was where do i mount my ingnitor for my ingition system is was mounted on my air box and the other problem when i started it up it was like my idle was turned up all the way but i didn't even touch it. And one more thing there is a funny clicking noise in my engine that just start happening any idea what it is. any info will help
Old Aug 13, 2001 | 08:44 AM
mordr's Avatar
I just took 1 of the nuts off the air box and installed the ignition stuff back on the same tab with the same bolt that was originally used. Clicking could be valves-try adjusting them and see if that fixes it. Check the linkage on your carb-throttle cable etc-maybe something got a little out of place.
Old Aug 13, 2001 | 06:24 PM
lightning's Avatar
i fixed the idle problem and the ingition stuff i took care of but i don't know about the clicking noise i just had my valves adjusted maybe a month ago but i'm not messing with so i'll take it to the shop just to see what is wrong with it and if its not to complicated i'll do it myself instead of paying a fortune to have it done. Because of the noise i didn't ride it yet with the K&N clamp on it yet. So how is it...does it give more power..throttle responce?
Old Aug 21, 2001 | 02:47 AM
1BEARMAN's Avatar
Hey Lightning
What was the part number for the clamp on filter?
Thanks Bearman
Old Aug 21, 2001 | 09:37 AM
Lurch's Avatar
The noise is one of two things. One is the slide on your carb. The second is your valves.
Remember, you don't have that big airbox there anymore to deaden the sound. Mine is very loud, but I'm getting use to it.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
