ATV winch switch location, if anybody cares to see where mine is now.
I extracted the toggle switch from the remote handheld switch unit that Warn sold me, and I mounted the switch (using goop) just inside the handlebar cover. See photo link below, if you care to look at it. I like it there. Nothing hits it. It is clean. I have memorized which way is in and which is out. I do not plan to mark which direction is which.
http://home.rochester.rr.com/yalsprus/winchbutton.jpg
I ran the wires neatly this time. I followed other wires, took off the red plastic cover over engine area, used wire ties, soldered, used anti corrode stuff on the connections. I did a crappy job the first time I wired for the winch. This is an awesome machine. It deserves to have only quality work done to it.
FYI, my relay is mounted to the aluminum rack mount bracket under the right rear fender. Why? I dunno, could not see a safer, more out of the way place for it. Warn gave me enough wire to do it anyway.
bzdok1234
30
Feb 23, 2016 01:55 PM
