Wider tires on Lakota Sport rubbing battery????
Thanks for the replys. Switching the rims will not work, there is a 2" off set on the outside. I was able to move the battery box about 1/2 in inward, that helped. 98 Lakota, How did you relocate the battery under the seat? What did you use to make the new box? No problem when jumping?
I made the box out of some 1" angle. There is a section in the very back of the frame that is the perfect size for the stock battery. I had to cut some of the plastic under the seat to clear the top of the battery and I also made a new brace for the rear brake caliper that is about 1 1/2" longer than stock to move the caliper back some.
bzdok1234
30
Feb 23, 2016 01:55 PM
John Boy
Jul 13, 2015 11:16 AM
