how to adjust shifter on 650
Old Mar 2, 2002 | 05:23 PM
couga21's Avatar
I searched old posts but found nothing. I was wondering does anyone know how to adjust the shifter linkage on a Prairie 650. And is the reason to adjust it because it becomes hard to shift between the gears? any info will be helpful
Old Mar 2, 2002 | 05:40 PM
coolinthewoods's Avatar
To adj your linkage remove the air box cover and access panel, then remove the shroud. There a linkage attached to the shift handle, loosen the two nuts one on each end twist the linkage to adj. Also are you useing the foot brake to shift gears?
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Beeline08
Nov 11, 2016 04:00 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Whitelx1
Oct 2, 2015 10:55 PM
wrencher82
Sep 30, 2015 04:27 AM
