prairie 650 ignition noise
Old Jul 18, 2002 | 04:34 PM
packardbell15's Avatar
when you turn the key to the on and off position you hear a noise from the ingition and you are suppose to hear it that is normal, but after your ride it for a while and turn the key off it makes a noise like its skipping or hesitating and u knock the housing for it and it goes away. when you turn the key back on it does it too. when im driving u can hear it if u listen and u tap on the housing and it goes away. can someone tell me whats wrong or if its happened to you.
Old Jul 18, 2002 | 04:54 PM
Dextreme's Avatar
Is it coming from the little motor thingy on the right side of the engine? Where is this housing your are refering to?
Old Jul 18, 2002 | 05:00 PM
yeh ur right that it is coming from the right side right above the transmission. it is coming from that little black thing. is it normal for it to sound like that. it sounds like its skipping. is that normal after u ride
Old Jul 18, 2002 | 05:21 PM
Dextreme's Avatar
It is normal that it will make an "engaging like noise" for a second or two when turning on the key and a "disengaging like noise" when the key is turned off.
Old Jul 18, 2002 | 05:28 PM
yeh but it sounds different when i turn the key on and off after riding for about 30 mins. its sounds like its hesitating and skipping. then after it cools off it goes away. when im driving if u put ur ear up to the noise u can hear it and u tap that little motor and it goes away. does yours make a skipping noise when u turn the key on and off after riding for a little while
Old Jul 18, 2002 | 05:35 PM
Dextreme's Avatar
Mine just buzzes, so you may have something wacko going on. I bet Nyroc will know what to do...maybe shoot him a private msg.
Old Jul 18, 2002 | 05:36 PM
whos Nyroc and how do i get to him or them
Old Jul 18, 2002 | 05:42 PM
Buckeye400EX's Avatar
From my understanding that is the engine braking system recalibrating itself, everytime you shut the machine off. It's normal, they all do it.
Old Jul 18, 2002 | 07:15 PM
Dextreme's Avatar
Nyroc is a member on this board who knows the P650 in and out. I haven't seen him post for few days, but you will find him on other threads.
Old Jul 19, 2002 | 12:26 AM
partsman2's Avatar
The noises you are hearing are completely normal.This is a solenoid motor that controls your engine braking (KEBC) system.If your engine braking seems to be working you do not have anything to worry about.The noise going away when you tap it is probably coincidental since the noises only last a few seconds when you turn the key on or off.It also will make pulsating noises when running very slow down hill as this motor is controlling the engine braking.
I want to know how you got your ear down there while you were driving it.
ReconBayou
Oct 16, 2019 02:24 AM
EIF
Apr 20, 2017 07:15 PM
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
kbazzy
Sep 26, 2015 11:26 AM
