P650 Lift Kit Question
Old Jul 23, 2002 | 11:44 PM
Chuckybrown's Avatar
Ok, a couple of questions:
If I install a lift kit, will I need to make any adustments concerning the drive shaft or front CV joints?
Also, with the addition of a lift kit, will any engine re-tuning need to be done if I am just going up an inch or two in tire size?
Lastly, I read one time that lift kits (for whatever reason, I don't remember exactly what I read) cause engines to run hotter. Any comments on that?
Thanks!
Chucky
Old Jul 24, 2002 | 10:58 AM
Bump
Old Jul 24, 2002 | 08:41 PM
bump...someone please answer?
Old Jul 24, 2002 | 08:59 PM
SgtRock's Avatar
Check with Highlifter and see what they have to say about it. I guess it all comes down to how high you go.
Old Jul 25, 2002 | 08:42 PM
mastrblastr's Avatar
If you install a lift kit, you will have to reset your toe-in on the front end. You won't have to do any engine mods if you don't want to. You do lose power by going up in tire size, but it is not catastrophic. Lift kits won't make your engine run hotter, but running bigger tires will, as it takes more juice to turn those big meats. I'm done.
Old Jul 25, 2002 | 10:27 PM
92LT's Avatar
The big downside to running lift kits is that they cause increased cv joint angles. The increased angles causes more wear n tear on the drivetrain. I run 27" 589's without a lift. I've heard of people running 28" tires as well without a lift.
Old Jul 26, 2002 | 12:52 PM
Cool, thanks for the replies. I am going to install 26" tires on the factory rims. Sounds like I am going to be ok, and probably better off without a lift kit.
Thanks again all!
Chucky
shimanok2
Jan 29, 2016 07:37 PM
QuadRiders
Oct 22, 2015 04:13 PM
bigred20653
Oct 2, 2015 10:05 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
bigred20653
Sep 19, 2015 02:11 PM
