P650 air filter cleaner
Old Jul 28, 2002 | 08:39 PM
packardbell15's Avatar
what should i use to clean the air filter in my P650. the manual says a high flash point solvent. where do i get high flash point solvent. if you dont recommend that then what should i use and what shouldnt i use. thanks
Old Jul 28, 2002 | 09:23 PM
nyroc's Avatar
I used to use PJ11 foam filter cleaner spray before I got K&N.
I think some people have used dish soap too.
Old Jul 28, 2002 | 09:29 PM
DustinMinnesota's Avatar
I use Klotz, just use a filter cleaner and not gasoline or solvent that is not designed for an Air Filter. Also use filter oil and not motor oil. Let your filter dry completley when you rinse it with water to eliminate "dry holes". Dry holes form after water evaporates because oil cannot penetrate where the water has been. I have a spare I use I clean one and set it back that way I am not without a filter in my box and it gives me longer till I have to replace the original because your supposed to replace the factory one after 5 cleanings. I payed 24.00 for my spare at the dealer. However if your running K&N the cleaning time is dramatically reduced and the filter is supposedly going to last forever, However if you ride in a lot of dust stick with the foam and get a Diamond G snorkel for improved airflow into your box. I am as soon as I ever get around to it.
Old Jul 28, 2002 | 10:18 PM
Metallikev's Avatar
hey guys..do you think I would need to rejet if I just put in a new airfilter...I wouldnt think i would??
Old Jul 28, 2002 | 10:52 PM
factory no, some of the high flowing ones may require a carb adjustment but rejetting I think is only if you open it up too much like univents and such with exhaust.
Old Jul 28, 2002 | 10:54 PM
where do i get pj11? do they have a site?
Old Jul 28, 2002 | 11:01 PM
most offroad or dealer shops or online. I even think Kawasaki sells it on their site as well.
Old Jul 28, 2002 | 11:08 PM
Metallikev's Avatar
cool..I would like to get a k&n but was told that the uni's are better..they are cheaper I think..but better?
Old Jul 28, 2002 | 11:18 PM
jlpier01's Avatar
I have two Kawa stock filters for cleaning rotation. I feel that they are very high quality and are not the bottleneck for air flow. I bought a KnN and it did not fit well at all. It allowed a buddy's smoke to go around the filter. Also in the silty dust I ride in, I feel more secure with foam protecting the engine.
I also agree with NYROC that the PJ1 is the best cleaner for foam. Just let it soak long enough and it will do the work. I use the Maxima FAB1 blue foam oil, it is really sticky, and you can see where you put it.
pgamboa
Dec 24, 2023 11:52 AM
2many2ride
Sep 27, 2015 04:35 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
