Installing a DuraBlueEliminator 2+2 rear axle on 2002LakotaSport300 ?
Old 08-19-2002, 10:49 AM
bigbad400's Avatar
Lakotasportrider how did you get that piston ring out and where did you buy the pliers to get them out.
Old 08-19-2002, 02:49 PM
LakotaSportRider's Avatar
Well first i removed the tires/hubs cuase then i took of the rear brake system thus having only the axle hooked up to the chassis.My goal was to remove the axle(because it was bent)so i didnt care if i scratched or hit it hard while removing it.I proceded with removing the 2 huge axle nuts in the brake hub side,then i hit the disc brake hub with a short 2x4 until it slided out .Then i removed the axle sliding it out through the left side (sprocket hub side)with the sprocket hub still on the axle.When i took it out the axle only had the sprocket hub on so then what you should do is only push it a little bit towards the inner side letting the piston ring show then hit it with a hammer and a flat screw driver until one side gives.Unless your not planning on taking the whole axle of i think your in for some real hassle.Hope this has helped you or any one ,Thanks.[img]i/expressions/face-icon-small-smile.gif[/img]
1986Vmax540
07-09-2021 09:53 PM
STLyamwar
07-25-2020 04:44 AM
toonces
08-05-2015 05:55 PM
Rider252
07-06-2015 03:37 PM
Quick Reply: Installing a DuraBlueEliminator 2+2 rear axle on 2002LakotaSport300 ?
