Hill climbing
Old Oct 5, 2002 | 12:45 AM
  #21
partsman2's Avatar
Because of where the snorkel for the air box is located you would be likely to have a problem with the air box filling up with water and killing the engine. I guess if you had forward momentum (remember - momentum is your friend) the snorkel might some how not fill up with water. If you fill your air box with water on any bike you're f**&ed. I do my best to not get in those situations. Just old age I guess.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Oct 5, 2002 | 01:10 AM
  #22
alltoys's Avatar
The bike has limitations and as long as you respect them, that goes for any machine use it for what it was meant and I am sure you wont have any problems. If you wanted a submarine try your local army and surplus store you might find something reasonable.
Old Oct 5, 2002 | 01:36 AM
  #23
Prairie1776's Avatar
Myself and a friend have dunked ours up to the headlights and not had any problems.
The only thing is KEEP GOING, 'cause if you stop the belt drive will take on water.
Then comes the fun of trying to get it out.
Can you say winch. [img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Oct 5, 2002 | 01:37 AM
  #24
MuddHound's Avatar
We'll do it KOD!
Tommyboy, I've never crossed deep water slow enough to know how deep it really is. My safety glasses are usually covered in mud and water and the wake distorts the true depth. But yes I have had water run over the top of my "tank" but if it was wake or depth I couldn't tell you.
Old Oct 5, 2002 | 07:45 PM
  #25
tommyboy84's Avatar
Do you have to be stopped to shift in to 4wd? also does it kick off when you reach a serten speed, can you still go fast with the diff lock on like when your getting a run for a hill?
Old Oct 5, 2002 | 08:26 PM
  #26
mastrblastr's Avatar
Tommyboy, here's the scoop on the 650.
1. It will climb anything you point it at. There is one thing you have to consider-----gravity. Any quad will climb a hill, this one just does it better than any of them due to it's extreme power.
2. It's not a submarine. It will cross water up to the headlights, but that's about it. If you want to go through deeper water, snorkel it.
3. It's got the most power of any 4x4 quad out there. Period.
4. You gotta be under 20kmh to put it in 4wd (that's what is in the book.) The same for taking it out of 4wd.
5. The 4wd stays engaged no matter what speed you are in. It doesn't care if you are doing 9kmh or 90kmh.
6. The front diff will stay locked as long as you hang on to the lever.
7. Go buy one.
Old Oct 6, 2002 | 11:32 AM
  #27
3TV, that was like dejavu!! We are connected like brothers---------------Ya right!!!!!!!!!!!!
Old Oct 6, 2002 | 11:46 AM
  #28
tommyboy84's Avatar
I have a question about the body size of it. from the pics I've been looking at the atv dont look very big when the rider is on it, is it atleast the size of a forman, bigger?' smaller?
dannytas
Sep 26, 2017 06:31 PM
Pgbama11
Jan 16, 2016 08:19 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
Pgbama11
Sep 10, 2015 08:20 AM
