Mojave
Old Oct 15, 2002 | 12:26 PM
bansheeman351's Avatar
Default Mojave
A friend of mine just bought a year 2000 mojave for $800. It smokes a little when you first start it and when you hammer down the field. We were going to install a high comp piston in it. but what should l do to stop it from smoking. I think its the valves or the valve seals. what do you think.
Old Oct 15, 2002 | 12:36 PM
gaff's Avatar
Default Mojave
leaking valve seals will plume blue smoke when you first start it. Worn rings will blow blue smoke when you get on it hard. Tell us what color the smoke is.
If the smoke is blue and it does it at start up and hammering on it, this engine was probably excessivly hot at one time.
Old Oct 15, 2002 | 02:08 PM
Default Mojave
I think it neads valve seals and rings. It blows blue smoke.
Old Oct 16, 2002 | 12:04 AM
Chris142's Avatar
Default Mojave
It's possible that the cylinder is not perfectly round,mine wasn't.
They press the sleeve into the cylinder,this may distort it...might not.But they dont check or hone it afterwords like they should.
Other possibilitys include a missing airfilter or a cracked boot between air filter and the carb allowing dirt into the motor.
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
RidE
Oct 19, 1999 06:10 PM
dunc_n
Aug 26, 1999 09:32 PM
BlackHawk
Jul 31, 1999 01:31 AM
