lakota whinning
Old Jan 17, 2003 | 02:25 AM
antix's Avatar
Default lakota whinning
i ported and pollished my head of my lakota and when i put it all back together and started it up it makes a loud whinning sound like a blown drag car. does anyone know what could be causing this?
Old Jan 17, 2003 | 08:14 AM
gaff's Avatar
How about the timing chain guides. Probably one of them not in place correctly and it's rubbing. First I would remove the auto tentioner and make sure it's not sticking and applying good preasure to the chain.
Then take the cam access cover off as well as the hand staert recoil. Turn it over by hand and see if you can hier the timing chain rubbing.
Old Jan 18, 2003 | 08:48 AM
mudnmyeye's Avatar
Antix, If you figure it out let me know. When I put mine back together, I got the same thing. I tore it apart again to find out what was causing the whine with no success. I've been running with the whine for a year now with no problems. One thing I did notice on re-assembly, The chain seemed real tight, I assumed it was from new gaskets ?
Old Jan 18, 2003 | 02:55 PM
antix's Avatar
so do you think it would be ok if i ignored? cause i can't find whats doing it
Old Jan 19, 2003 | 08:52 AM
mudnmyeye's Avatar
I don't know if it's ok. Obviously, something changed, and you'd think that if you put it back together the way it came apart...it wouldn't whine. I'm say'n that I have run it for a year with the wine with no problems. The whine also decreases over time. Now its hardly noticible.
kwackermann
Jun 24, 2015 10:18 AM
KawasakiLakota
Aug 23, 2000 11:57 PM
blazer1969
Aug 23, 2000 02:45 PM
shockwave
Aug 20, 2000 07:57 AM
cstark
Oct 15, 1999 01:45 PM
