Stalling problem
generally I have to choke it to start it again, sometimes she'll start without the choke after it sits for :30 seconds, but without the choke it will either die again, or run at about 500 rpm for 10 - 15 seconds before it gets up to full idle again, & if I try to hit the gas to get it up to the normal idle rpm it will just die again.
I was going to try & keep backing the pilot screw out until maybe it did some good, I have it at about 2 1/2 turns right now, I think it's helping.. Yea the idle seems to be okay, Iv'e played around with that alos.. Is there a needle in the carb that also controls how lean or rich the engine runs, I was wondering if something else needs adjusting.
#15
FYI: Should anyone else out there experience this problem, the fix I found was the Valves were out of adjustment. I adjusted the valves back into spec & no more stalling, even made it run much better at start up & idle in the cold.
#16
Uinthas
How hard was it to adjust the valves. I need to take a look at my daughters new ozark...she had a little stalling problem after we owned it for three months...called the dealer and before he even looked at it said it would cost a $150 bucks to reset the valves. What level of mechanical expertise would you say one needed...thanks for the info...where do you ride in ogden area
#17
It was not hard adjusting the valves. The hardest part is getting to them, for me that ment removing the left tire, the iner wheelwell cover for the exhaust vavle, & for the intake I had to remove the gas tank. That stuff just requires removing bolts & screws, not to bad. The vavle adjustment itself is just about as easy as gaping a plug, you just need to get your engine set at TDC & then get your feeler gauge in there & check them. If there off just loosen the lock nut & then there is a screw on top you adjust the gap with. If you dont have a manual I'd suggest getting one, it will give you all the details as far as how you get your motor set at TDC & where to check that at. If you need any more tips or help let me know.
This winter I have been riding the snowmobile trails on Monte Crist & the Mirror Lake Highway. In the Summer close to home I usually just ride up to Willard peak, or the trails around Bountiful peak, but my favorite is the Unita's mountains, there's all kinds of trails up there.. [img]i/expressions/face-icon-small-smile.gif[/img] Lots of places to ride in Utah, especially southern part of the State, I just havn't made it down there yet..
