warn winches
Old Feb 24, 2003 | 09:43 PM
hillbillyman's Avatar
Default warn winches
does anyone know if a the new warn winches=(3.0 i ) will work on the factory mounting brackets on the p360?
Old Feb 24, 2003 | 10:03 PM
thumpin650's Avatar
The bolt pattern for the 3.0 is the same as the A2500 and 2000. If it works for those warns it should work for the 3.0ci.
Old Feb 24, 2003 | 10:12 PM
hey, thanks. was the 3.0 hard to wire? whats the best price you found the 3.0 for?
Old Feb 25, 2003 | 11:19 AM
BrianT's Avatar
Check out this place
http://www.onlyatv.com/index.html
$360 plus $20 for shipping. The mount for my 650 was another $29 incldng shpping. Thats where I'm going to buy mine.
Old Feb 25, 2003 | 11:59 AM
BigMiks's Avatar
The bolt pattern is the same, Yes. The Style is different, as to where the drum full of wire is placed. The 3.0i's drum is actually centered on the whole system. Not like the SuperWinch(drum on the left) or the Warn 2000/2500(drum on the right). Mounting the Warn 2000/2500 with all the mounts from Kawi, flip the winch upside down to put the drum on the left like the SuperWinch.
I made a custom mount from the plate that comes with the Warn 3.0i and a 8" x 4" plate of 3/16" steel. It looks Quite Perfectly centered. The front obviously I had to mod a wee bit. I wanted the roller fairleed to be mounted to the frame like it looks it was made for. Only prob was the frame cutout and holes were to the left as youlook @ it. So I had to drill and cut a hole for the winch cable to go through. I'll have some pics soon if you guys would like.
Matthew
Old Feb 26, 2003 | 10:01 AM
BigMiks's Avatar
I just posted the winch 3.0i pics in my bio if you guys are interested as soon as it all gets approved.
Jeff Roper
Feb 1, 2022 11:48 AM
Johnny Mac
Aug 15, 2019 03:13 PM
panicmanic
Sep 28, 2015 12:59 PM
cboler9
Sep 24, 2015 08:35 PM
chewy78
Sep 8, 2015 10:37 AM
