stock air filter on p650
Old Mar 14, 2003 | 03:05 AM
rammy's Avatar
Default stock air filter on p650
what do you guys use to clean your stock airfilters with. the owners manual just says to use solvent. any suggestions?
Old Mar 14, 2003 | 03:08 AM
rammy's Avatar
another thing, do you think that the k&n air filter cleaner and filter oil work on the stock foam filter?
Old Mar 14, 2003 | 07:29 AM
nyroc's Avatar
Work? Maybe. But it isn't right to use it.
Get foam filter cleaner and foam filter oil spray cans from a motorcycle dealer. I usually use dish soap after cleaning it as much as I can with the foam filter cleaner. Rinse thoroughly. wring it out. Place filter near a fan to dry it out. Don't use any heat.
When dry spray both sides with filter oil.
Old Mar 14, 2003 | 10:15 AM
rammy's Avatar
nyroc
the reason why i asked this is because i did go to the dealership the other day asking for some foam filter oil and the ONLY thing they had on the shelf was a couple of cans of that k&n oil. i asked them if that would work and they told YES so i paid $10 for this little bitty can of spray oil. after i left, i got reading the back of the can and it said "especially designed for gauze filters" so i turned around and went back there and got my money back and told them i just had a funny feeling about that and that i wasnt going to put that on MY filter. just thought i'd ask you guys to make sure.
is there an arrow on the belt to show which way it goes on? if so can you see it by just pulling the cover off?
Old Mar 14, 2003 | 11:43 AM
CRUNCHMAN's Avatar
The oils are very different! Foam filter oil is sticky; gauze filter oil is nothing more than ATF or power steering fluid. Don't pay the extra money for K&N oil when you can get a quart of it for about $1. You can clean your foam filter with any household degreaser like Simple Green or Formula 409.
Old Mar 14, 2003 | 11:52 AM
nyroc's Avatar
rammy, it might be ok while you ride in the snow, but get real foam filter spray if you ride in any kind of dust.
fordfaithful21
Dec 7, 2015 05:52 PM
Albertaboyy
Sep 9, 2015 09:51 AM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
