Help installing hmf exhaust on v-force
Old Apr 16, 2003 | 11:21 AM
NYVForce's Avatar
Default Help installing hmf exhaust on v-force
Can I use the jetting that comes with the dual exhaust 142,145 at 500' above sea level if I drill holes in the air box lid and remove the snorkle thanks.
Old Apr 16, 2003 | 01:12 PM
STAKK's Avatar
i think if you do the air box mod's also it will be a little lean at your elevation, i would put a 145 in the front carb and a 148 in the rear if you are going to mod the airbox........
Old Apr 16, 2003 | 07:09 PM
Vforcer's Avatar
I think Stakk is right .... I am at 1000' here in Akron .....
I am using the HMF recommendations..... plus a dial-a-jet system
( worth about two more jet sizes )
And two holes in the air box...... and I removed the snorkle
Old Apr 16, 2003 | 07:17 PM
Plumrman's Avatar
Hey Vforcer...... I am going to add the HMF duals as well, along with a dial-a-jet syatem, and thinking about the Airbox Windows from dial-a-jet also. Did you use the dually dial a jets, or the standards?
Is the quad much faster in its modified form?
Old Apr 16, 2003 | 08:00 PM
Freakazoid's Avatar
Based on the information I have found the dual dial-a-jet sounds like the ticket to get it dialed in.
Old Apr 16, 2003 | 10:07 PM
Vforcer's Avatar
There is one dial-a-jet induction jet in the rubber boot on top of each carb......
It that the "dual dial-a-jet" system ????
I used the sliding air valves from the dial-a-jet people also ....
Summary ... my bike has two air holes, 142/145 jets, and the dial-a-jet system , with the dual HMF exhaust
Old Apr 17, 2003 | 07:08 AM
Freakazoid's Avatar
There are 2 nozzles for each carb, so 2 rubber boots.
http://www.thunderproducts.com/dial_a_jet_dually.htm[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 30, 2004 | 03:21 PM
Strokem's Avatar
---I need help with the Dial - a -Jets I melted my head or blew an oil ring.
fordfaithful21
Dec 7, 2015 05:52 PM
Bonzhonda300ex
Sep 17, 2015 10:44 AM
Sep 10, 2015 01:56 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
