lt80 question for mr.lt80
I wanting to put a kx65 intake on the LT have you ever done this n how hard is it to make it work. Give me some advice. I wanna stay away from the dg Carb kit. Mb even use a flange mount 22mm Carb.
It may be possible. The cases would have to be machined to accept the other reed cage.
Years ago I had another flange/boot type of carb on a LT.
Chris Grissom has a reed cage/carb set-up. I think he uses a 22mm carb.
What you hoping to gain?
Well I have my motor at Hetrick racing getting the big bore and stroker. I enough the stock Carb isn't gonna be enough. So im looking to flow some more air and fuel to go with the motor work but I dont Like the dg Carb setup. Do you Have any suggestions on what I can do
