Eton Viper 70 has me stumped
I just rebuilt a viper 70 because the compression was low, and a rebuild kit for this quad is cheap. So I finished it, made sure I put the piston in the right way, oiled everything as I was assembling it, and it will not start. Only will it backfire out of the exhaust every once in a while while I am cranking it over. It has good spark, is full of fuel, air filter is clean, and i just cleaned the carb. Any ideas on what may be wrong?
Yep the plug is getting wet. I've even tried squirting fuel directly into the combustion chamber and it still only backfires. I guess I'll check the compression today and let you know.
I am still using the oem cylinder. All i replaced was the piston, rings, and gaskets of course.
