Honda TRX 90 Tires
We have used a tire called shredder (18x9.5x8) for mx racing for some time with good succsess. It is a low profile tire with a stiff sidewall which helps the bike slide through the corners better. Another good choice for trail riding would be the turf tammer in the same size as the shredder. We recently switched to the razor tire for more traction in mx applications. It is not available in the 9.5 size. The narrowest it comes in is 10inches.
Thanks for the reply. I believe the stock tire is 19X8X8 a little wider is not a problem but I think I would like to go a little taller to get some ground clearance as well, Any suggestions? As I already mentioned we are riding in more mud and rocky conditions every little bit helps.
07-24-2015 11:57 AM
07-22-2015 05:00 AM
