LT80 front wheel spacers?
I thought about that too. With the spacers that would work ok. Without there is not enough clearance with the brake arm. I wasn't sure at first if my spacer idea would work. On the back wheels that would work as well. I figured the air pressure in the tire should keep the JBWeld in place. If it fails I will let you all know. Thanks for your comments though.
on the rear wheels you can just invert,the valve stems wont be in the way of anything,if anyone is int i know a way to get about 4 inches in the front using some eton stuff all bolt on it just changes you bolt pattern to 4 on 110
Jul 21, 2015 03:03 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
