Lem Cayman 50
Old Sep 16, 2016 | 09:09 AM
  #21
firsttimerider's Avatar
Smile 125 ml
Thanks for this. 125 fit nicely on the fill line. I think you are right, a tad more would be suitable.
Old Sep 17, 2016 | 11:59 AM
  #22
Default Clutch gear
We are having trouble keeping the gear nut on the end of the shaft holding the clutch in place from coming loose. I tried using thread lock but still did not hold. I understand there are different strengths to this substance. Maybe a stronger strength could help. Any suggestions.
Old Sep 17, 2016 | 12:10 PM
  #23
Loctite won't hold this nut. Need sleeve retainer. We used Wurth brand products,but I'm sure this should work also. Takes plenty of heat from a heat gun or torch to help break the nut loose when set.Permatex 64000 - High Temperature Sleeve Retainer | O'Reilly Auto Parts Loctite does make a similar product but expensive. Smaller tubes may be available at area auto stores.https://www.zoro.com/loctite-retaini...Q&gclsrc=aw.ds
Old Sep 18, 2016 | 08:31 AM
  #24
Thanks. That should solve that problem. Another issue is the clips that holds the links to the shoes keep slipping off. There must be a better way to keep the links from falling apart.
Old Sep 18, 2016 | 09:47 AM
  #25
Make sure you have the closed end of the clip facing the way the engine turns or the clips can sling off. Plus wouldn't hurt to use a little loctite on them and see if it helps.
Old Oct 8, 2016 | 09:04 AM
  #26
Default basket
The basket in the clutch assembly has a lot of play, that is to say is quite loose. I am wondering if this is a serious problem. It does not make contact with anything. I am sure when the shoes make contact and the vehicle is moving it would be stable. Any thoughts here.
Thanks.
Old Oct 8, 2016 | 11:44 AM
  #27
If it's back and forth play there is supposed to be a washer behind the basket. If the whole basket is wobbly,then the brass bushing has worn out.Not sure if one is even available for this. You might look through the S5 and S6 engine parts.Morini Franco USA
Old Oct 8, 2016 | 05:45 PM
  #28
Default basket
I will have a look at the basket and check for washers and the state of the bushing.
Thanks.
Old May 25, 2018 | 10:24 AM
  #29
Default ignition kit for cayman
I am having trouble getting a spark with this replacement ignition kit.I seem to get a voltage from the stator and flywheel so I am presuming that means the primary circuit is okay. But there is only a faint voltage at the plug. I am wondering if the main wire going to the plug is faulty or is the secondary coil faulty. I have limited knowledge of the system. I hoping this coil is okay as I had it delivered back at the end of March and have just got around to installing this kit. I believe it is installed correctly. ay suggestions would be helpful.
ffjerid
Apr 2, 2013 05:15 PM
FrenchGuy
May 14, 2007 05:29 PM
hddadx4
Jun 8, 2005 02:36 PM
racingfamily
Sep 21, 2004 06:53 PM
Raptorflash1
Aug 29, 2004 02:15 PM
