oil ratio Question
Old Apr 13, 2004 | 09:40 PM
Bluetickracing's Avatar
Default oil ratio Question
I've been mixing my oil at 32:1 with maxima 927. There seema to be alot of smoke more then I like. Oil just drips out the Exhust pipe. Plug is to rich for me I have played with the air screw some but still to much oil in the pipe. I mixed up some 36:1 fuel somewhat better. Is a 40:1 mixture to lean. I run a 40:1 mixture in his Polini x3 works dirt bike, and it revs up to like 13,000 to 14,000 rpm. So I was gonna try some 40:1 in his Arctic Cat 50 quad. I just need some your thoughts.
Old Apr 13, 2004 | 11:04 PM
geo's Avatar
geo
been running 40:1 with absolutely no problems on two machines, with beautiful looking pistons and bores using Klotz, Yamalube, and/or another "special" brand.
check your compression. if the motor can't build enough heat in the combustion chamber (due to lack of compression, etc) then it'll smoke and drip.
your "air-screw" has nothing really to do with it- it controls low-throttle-opening fuel mixture (like idle), and more precisely is either called an idle mixture screw or low-speed screw. if your plug is too black i'd make sure your main jet is correct- that'll have the biggest influence on the condition of your plug.
Old Apr 15, 2004 | 10:45 AM
LT80's Avatar
LT80 Expert
As great of oil as ppl say bean oils are, I can't stand them.
I think 40:1 would be fine
I also think I'd switch to Klotz -50, Maxima superblue,Torco GP-7, Amsoil, etc. ...Synthetics
My 2 cents [img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 15, 2004 | 09:07 PM
Thanks for the reasurance. I felt that 40:1 would be ok. I run Maxima 927 in all my 2-strokes.Thanks again.
Mike.
___________________________
#838-01 Polini x3 works-Michaels
#838-01 Husqvarna cr50 Jr-Michaels
#838-04 Arctic Cat 50-Michaels- Big Gun exhust, Malossi clutch kit,Malossi cdi, Malossi Reed block and reeds, Acerbis hand guards, 19/35 Rebel Gears, Pro Design kill switch,Twin air filter pod, Dougles Alum wheels, Holeshot tires,rejetted,removal of oil injecter,
03 Suzuki lt-80-Michaels
04 Suzuki DRZ-125L-mine
02 Yamaha Big Bear 400 4x4-mine
____________________________
"Keep it pinned to win"
"Don't ride faster than your Angel can fly"
EIF
Apr 20, 2017 07:15 PM
2many2ride
Sep 27, 2015 04:35 AM
Honski250r
Sep 26, 2015 09:40 PM
rockinkgin
Sep 25, 2015 01:52 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
