Front Brake Adjustment
Old Jul 1, 2004 | 10:20 PM
ponyboy's Avatar
Default Front Brake Adjustment
Hello All Need your advise. I have a 03 eton 90. I have adjusted the front brakes at the lever all most all the way out, so I thought I needed new shoes, well I took the front drums off and the shoes look ok. Compared the old shoes with the new and can't see any wear differance betwen them. Is there anything I'm over looking ? The bike stops ok but am running out of adjustment. Could the cable be streched to far? Thanks for you help.
Old Jul 1, 2004 | 10:36 PM
BIGGONE's Avatar
I think you just hit the nail on the head.
I would say how your describing it that would be the problem.Let us know!
Old Jul 2, 2004 | 01:13 AM
oldyeller's Avatar
Bit of a long shot but I'm wondering if the drums are worn?You could always turn the little arms back on the splines right at the hubs to give you your adjustment back but if the cables have stretched that much they might be ready to break.
Old Jul 2, 2004 | 03:21 PM
confusedbuyer's Avatar
I've ALWAYS adjusted my brakes the way old yeller described, move the arm back 1 spot on the spline. you'll probably get 2-3 spline adjustments, plus the cable adjustments between each spline adjustment. this way you get to use up all the brake shoes material. I think it's cuz the brake cam doesn't open that much relative to the cable, so you have to do that to get the wear out of the shoes.each spline adjustment opens the cam a little more. I don't think your brake cable is stretched at all. BTW, on my yamaha and Suzuki, I NEVER had a brake cable snap because of this.
my best guess is the shoe material may be poor. many have said the off-shores use a material almost like MDF or particle board.
Reactant
Mar 30, 2022 02:08 AM
JackTheKing
Jul 14, 2015 09:09 PM
MNatv89
Jul 7, 2015 11:36 AM
jettman
Jul 6, 2015 12:16 PM
Mphillips
Jul 2, 2015 07:20 PM
