Yamoto 150cc tips, mods?
Old Aug 30, 2004 | 04:36 AM
timhood's Avatar
Default Yamoto 150cc tips, mods?
I'm speaking of the 110 here, but I would assume they are essentially the same in this regard.
It was basically a heavy-duty piece of cardboard blocking the filter for the air box. The cardboard had about 6 3-hole punch size holes punched through the otherwise 6"x8" cover. After removing it, I noticed a deeper growl and better top-end performance (actually more power in all three gears).
To remove it, I simply removed the 4 clips that keep the front plastic grille in place. then popped off the black plastic cover on the air box. Beneith that was the cardboard which I removed, then put everything back in place. The spring-like clips were a bugger to reinstall, but I got them eventually.
I would say the bike got about 10%-15% performance once the air restrictor was removed. Also, I opened up the speed limiter so the atv was not held back any.
Old Aug 30, 2004 | 10:03 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Thanks timhood, I own the 150 yamoto and I can't find it anywhere.I did not think you were talking about the screen in front of the filter.
Old Aug 30, 2004 | 01:21 PM
joakim's Avatar
on the 150cc yamoto the air box is mountet under the seat.
cant find anything in the airbox that is blocking the air intake.
i thing my yamoto 150cc is just going 40-50 km/h i thing that would be like 30 somting in mph
is ther any way to make it faster
Old Aug 30, 2004 | 02:05 PM
Cheapass's Avatar
What is your altitude? The Yamoto engines are tuned to sea level, and on the low side at that. I am at 7000ft, and had to open up the airbox to equalize on my 200. just took the airbox lid off and tried for a bit. Read the plugs, and they were light tan (Perfect) as opposed to slightly dark and damp (very rich) before I opened the box up. I now run a pod filter for ease of cleaning.
I may clear out the exhaust, as it is baffled AND wadded. No need for that wadding. Then I will likely have to jet a tad richer, or put the airbox back in.
Old Sep 13, 2004 | 11:44 AM
  #15
jcotti's Avatar
Hello all, first timer here! I am planning to buy my son (8 yr old, 90lbs) a Yamoto 150cc from a place called Raceway ATV in NYC next month, they do free shipping and the price is around $1500. Reading all these reviews is GREAT for someone like me that doesnt know much about these quads. Does anyone have any feed back other than the standard on these bikes? Like how hard it was to put together if they had to? The one I am getting needs some assembly. Do I need any out of the norm tools? Thanks to all that reply and this is a great place for newbies to get info. Cheers
Old Sep 13, 2004 | 12:39 PM
  #16
KTM Patrol
Former Chinese POW!
Welcome to the forum jcotti, I put my wifes quad together, a yamoto 150, and it was no big deal.A few metric sockets and box wrenches is all that is necessary. You need to unbolt it from the metal crate and then install the wheel's, fill the battery and install it. Lift the handle bars and tighten. The most important part is to Loctite everything. Especially the smaller bolt's, 6mm etc... I would reccomend changing the motor oil before starting it up also. I dont think that the quality of chinese oil is that good and a quart of oil is cheap.Especially compared to the metal parts it protect's. If you have any mechanical skills it should be pretty straight forward. And advice is real easy to get right here. Usually with pretty quick turn around time.Hope this helps and please feel free to ask as many questions as you want.
Old Sep 13, 2004 | 12:56 PM
  #17
jcotti's Avatar
Thanks for the tips. I am pretty handy and can change the oil on my truck. Can't imagine a quad will be much dif. What do you mean by fill the battery? Has anything ever broken and needed a part replaced? How easy was it to get a part? This may not be a forum for this question, but here goes.
I have never owned a quad for myself, but have ridden friends quads plenty of times. I am planning to buy myself a quad when tax season comes (hopefully I'll get a good refund)!!! I have been looking at dif ATV's and I really love that Raptor look of the Yamaha Raptor 660. Is this to much bike for me. I am about 6'0 and about 200lbs. I dont want to buy a small one and find that I need to re-buy in a year or two. I'd rather buy big and ride slow until I am more experienced and comfortable. Any thoughts? Thanks again, this place is great!
Old Sep 13, 2004 | 01:28 PM
  #18
KTM Patrol
Former Chinese POW!
jcotti The battery justneeds to be filled with electrolite. It comes with it and is very simple to do. I have just recently needed a part for my yamoto , mywife fried the rear caliper last saturday, leftthe parking brake on. I e-mailed yamoto and hope for a answer today will let you know. I am assuming that you have read all the post's under Yamoto 150 Review as well as this post. Lots of info there.As for your other question, I am not a quad guy but you seem to be the perfect physical size for the raptor 660.
Old Sep 13, 2004 | 04:18 PM
  #19
jcotti's Avatar
Thanks for the help. I think I am going to persue this Yamoto 150 a bit more. The feed back that i have seen looks good. Where can I find more reviews? other than in here. I only see this page.
Old Sep 13, 2004 | 05:07 PM
  #20
KTM Patrol
Former Chinese POW!
About half way down "kids quads and other atvs" in a thread called "yamoto 150cc review"
dannytas
Sep 26, 2017 06:31 PM
kbazzy
Sep 26, 2015 11:26 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Sep 23, 2015 06:23 AM
PrairieDog126
Sep 16, 2015 01:33 PM
