Cvt Tran. ?
Old Aug 22, 2004 | 04:13 PM
Bluetickracing's Avatar
Default Cvt Tran. ?
We run a 19/35 gears in the little mans Arctic Cat 50. I chose the 35 rear for a good all around both low end and top end gear for woods racing. But he's been running some Mx races and needs some more top end. I was thinking of a 29 or 30. My question is,will the cvt transmission make up the difference on hill climbing power? Or will I have to change back to the 35 for XC races. To make it clearer will the 29 pull like the 35 on hills with a cvt trans.Or will it have less power on the hills.
Old Aug 23, 2004 | 11:13 AM
LT80's Avatar
LT80 Expert
Default Cvt Tran. ?
What gearing was stock?
My guess is that you will indeed need to change gearing back.35 to 29/30 seems like a big jump.
The 50's usually need more things than just a gear change. Did you get a pipe yet?
Old Aug 23, 2004 | 06:33 PM
Default Cvt Tran. ?
The stock rear sprocket was a 50t. I put a Kpii pipe on it,but I took it back off. The stock pipe with the Expansion chamber worked better with the clutch kit. This quad is a AC 50.Total mods are the following. Airsal head, Malossi reed and cage, Malossi cdi, Malossi clutch ,rejeted and moded air box. Then I changed the gears from 19/50 to 19/35.I really don't want to put any more money into this quad cuz the season is almost over. I was just wanting to get some practice in for next year. A sponsor is gonna build him a new Kasea for next year. All for free.
#838-01 Polini x3works-Michaels
#838-01 Husqvarna-Michaels
#838-04 Atctic Cat 50-Michaels-Airsal head, Malossi cdi,Malossi cdi,Malossi clutch,Douglas wheels,Snow Hog tires, Acerbis hand guards,ProDesign tether,Rebel sprockets,rejetedand modded airbox.
04-Suzuki DRZ 125L-sons
02 Yamaha Big BEar 400 4x4-Mine
2004 PKM Motorsports Promotions XC champion (4-6) 50cc open Quad
2004 Sponsor: Dirt Works Cycles and ATV's
"Gotta Pin it to win it"
" Don't ride faster then your Angel can Fly"
outbackmac
Dec 5, 2008 11:43 AM
edmonds27
Oct 6, 2008 11:45 PM
orky4969
May 16, 2004 11:49 PM
SgtRock
Jan 27, 2004 12:33 PM
lbz300EX
Jan 31, 2000 05:26 PM
