LT80 Starter question
Old Nov 3, 2004 | 01:00 AM
bmiliate's Avatar
Default LT80 Starter question
[img]i/expressions/face-icon-small-confused.gif[/img]
1989 LT80 with electric start and pretty new battery. Starter cranks over the engine, but the quad won't start unless I push it along (walking pace). Then, it starts right up. Assuming that the clutch is engaging too low in the revs, but need some advice.
Thanks.
Old Nov 3, 2004 | 10:25 AM
LT80's Avatar
LT80 Expert
Pushing it shouldn't have anything to do with it.
I guess I'd start with the basics:: new spark plug, clean the carb, do a compression check.
If pushing does effect it there may be a problem in the clutchs as they should roll freely.
Old Nov 3, 2004 | 10:29 AM
bmiliate's Avatar
Must be the clutches. While I'm in there, I've seen some of your posts re: eliminating a couple rollers. Do you remove opposites? Does it affect clutch life?
I've seen a lot of your posts - thanks for the help.
Old Nov 4, 2004 | 11:31 AM
bmiliate's Avatar
LT80,
To get at the clutch and replace rollers, etc., are there any special tools - pullers, etc.? How difficult for a non-wrench?
Thanks.
Old Nov 4, 2004 | 02:59 PM
LT80's Avatar
LT80 Expert
Rollers: yes you remove opposites.No problems with abnormal wear.
Removal: An impact wrench is needed to remove the front and rear clutch nuts. Other than that normal metric tools is all that's required.
ei:14mm wrench/5mm allen wrench/8mm wrench/17mm socket for the clutch nuts/phillips head screwdriver/10mm wrench...
I allways recommend servicing the clutchs, but I'd do a compression check on this one also. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Nov 4, 2004 | 05:24 PM
Rudedog's Avatar
I'd also say to "check the compression"
Rude Dog
ghost civic
Jan 15, 2020 07:43 AM
ghost civic
Jul 19, 2015 10:13 AM
Desimation2k8
Jul 17, 2015 12:37 AM
ghost civic
Jul 15, 2015 10:48 PM
mudpig79
Jul 13, 2015 03:31 PM
