KFX 50?
Old Sep 19, 2005 | 03:34 PM
  #31
bulldogfallon's Avatar
Default KFX 50?
Do you guys run premix?
I found that running the castor 927 as a premix really makes the bike run good...
Old Sep 19, 2005 | 08:51 PM
  #32
Default KFX 50?
I can't find your previous post on tire size for the LT50.
What combo did you get? all same size or wider in the back?
thanks
Old Sep 20, 2005 | 10:21 PM
  #33
lt502000's Avatar
Default KFX 50?
For the front went with douglas 8x6 wheels shredder 16x6.5x8 tires
with douglas 8x7 wheels with the same tires for the rear which lowers the profile a little
Old Sep 20, 2005 | 10:28 PM
  #34
lt502000's Avatar
Default KFX 50?
Hey surfdude keep me posted on the clutch from ct an i really want to know about the wiseco with the head mods. I did some light dremel work in my sons head didnt want to get to crazy. were that brass fiting goes in the intake port I dremeled it so it isnt sticking out into the middle of the port
Old Sep 21, 2005 | 09:42 AM
  #35
Default KFX 50?
I am going to go with your recomendation.....I guess the nerf barfs need to be welded on?
Thanks for the info!!!
Old Sep 21, 2005 | 10:16 PM
  #36
lt502000's Avatar
Default KFX 50?
youll be satisfied in the end all that work is well worth it.
Old Sep 25, 2005 | 07:20 PM
  #37
bigdumbfun's Avatar
Default KFX 50?
Hey, I have a LT50 with the usual mods (removed restrictors, piggy back jet removed, needle raised, and airbox opened) and I have seen huge improvements. However I noticed when the kids are riding it hard and get it off camber, like a hard corner with a berm, that it stubmles BAD if they back off of the gas and then get right back on it. Like it is starving for gas. Float adjustment? I can get the boy to hit the same turn with constant pressure on the gas and no stalling. I get them to go in a staight line WOT and cut the gas and get right back on it and no stumble. But I can predict it in the corners by how hot they are going in and if they let off of the gas.
Anyone else dealt with this?
And to the newer guys with the 50....You can see in my pics that I am a big guy (280#) and our 50 will get me up our gravel driveway now and it is about 100' long 15 degree climb. I haven't even rejetted yet or put on a pipe. Then again were not racing out here either. But it feels like I have almost doubled the power with no $$$ and minimal tinker time.
Old Sep 27, 2005 | 01:16 PM
  #38
Default KFX 50?
Just got the nerf bars in
Should I just bring them into the machine shop and ask them to add a few inches and weld these on?
Any words of advice or helpful info to direct them....Seems like it would be a pretty straight forward request, but until it is done you never know
Thanks
Old Sep 27, 2005 | 02:05 PM
  #39
Default KFX 50?
Where can I find those close up pics? I am off to the machine shop tomorrow after work..
Thanks for all of your help
Old Sep 27, 2005 | 09:27 PM
  #40
lt502000's Avatar
Default KFX 50?
ON my thread called here are some pics of my boy on his lt 50 password: 200079
