GPX Raider 90?
Old Feb 9, 2005 | 10:50 PM
fireride's Avatar
Default GPX Raider 90?
Hey defcon5, how do you like the yamoto 70? THinking of buying on for my daughter. Sorry its off the subject but need some input.
Old Feb 10, 2005 | 10:08 PM
defcon5's Avatar
Read my post in raceways forum.
Old Feb 11, 2005 | 09:53 AM
defcon5's Avatar
BUMP!
Old Feb 12, 2005 | 02:42 PM
defcon5's Avatar
BUMP!
Old Feb 15, 2005 | 12:10 AM
  #15
defcon5's Avatar
BUMP!
Old Feb 17, 2005 | 11:01 PM
  #16
watzupdog's Avatar
Hey defcon. Get the hint. BUMP BUMP BUMP. Nobody is going to respond. Especially after you blew of fireride. BUMP
Old Feb 17, 2005 | 11:56 PM
  #17
defcon5's Avatar
Now why in the hell would I want to write a review twice when all he has to do is search.
P.S
BUMP!BUMP!BUMP!
Old Feb 21, 2005 | 10:03 PM
  #18
yamapower1's Avatar
These quads are more or less all the same.There is a korean plant producing the basic machines and smaller companies are adding a name and plastic configurations..They are supprisingly well made machines.I will bet that Will 67 has problems with a cold start becouse
his Yamoto isn't jetted correctly.
Old Feb 27, 2005 | 11:04 AM
  #19
Will67's Avatar
Yamapower, I believe you're correct on the fact that they are all roughly the same. The GPX has been a good machine. On the Yamoto cold starts, I had Yamoto send me a new carb and it fixed the problem. Surely they are all jetted the same from the factory. I'm certain the auto choke was not functional on the original. Either way its a known fact that for the price, one should expect these things I guess. So far, the dealer has been outstanding in helping correct the problems and I can't complain.
Old Feb 27, 2005 | 05:54 PM
  #20
Bengen's Avatar
Only problem we have had so far is the choke cable outer housing wasn't fully seated at the carb and didn't work properly. Not a huge deal but might be a problem for the not mechanically inclined. Had to richen it up as it is in the 20's here. Also ran first tank with 32:1 mix in case any air in oil injection system. Price has gone up since we got ours at X-mas. We went with 2-stroke as we want to race. If only trail riding I would look at 4-stroke machines. IMHO 2-strokes our on the way out due to regulations and demographics. Like the rear foot and hand brake. Foot brake lever is way to high so shortened and re-welded ours. Might not be an issue trail riding but not natural feel for racing as kids have to lift foot off peg/runnig board to much instead of rotating foot. I got a chain tensioner from Unison in California for less then $25.00, a must have bolt on. Ours didn't come with reverse, was offered as an option. Don't need it for racing but still thinking of getting one. Didn't look like much to install/remove for racing/trail riding. Unison will have electric actuator on theirs next year instead of manual lever. May wait for this as not sure if electric will be interchageable for manual lever. IMHO the shocks/springs are way to stiff. We are getting a set of Works shocks. Can't believe it would be hard for manufactures to wind some softer springs for these.
The Hulk
Mar 19, 2009 08:45 PM
kman01
Jan 2, 2005 11:10 PM
Bartman
Jan 28, 2003 12:47 AM
