Carb for Dinli Diamondback
#22
Now I have a question with jetting. I plug off both sides of the oil pump, changed the carb, filter, throttle cable, and installed the racing intake. When I originally installed the carb I used the 110 jet. I warmed up the bike, made some adjustments to the air screw, everything looks good, took it for a test ride and it seem sluggish. I then changed the jetting down to 105, the bike rips through the midrange still feels sluggish on top. I put a new plug in, warmed up the bike, then rode for about 10 minutes. The plug looked okay, it was a brownish, not white. Any advice on if the jetting is right. Could it be the wrong size rollers in the clutch, remember I'm using the Koso power up kit?
110, 50, 90cc, atv, carb, carburetor, changing, diamonback, diamondback, dinli, gas, mixing, parts, ratio, stator
