Baja 90cc
Old Nov 18, 2007 | 06:06 PM
  #391
auzburner's Avatar
Default Baja 90cc
I did it! No governor. on my CDI box there is a green housed dual screw connector. In other words it has a chromed piece of conducting metal which makes the circuit between the two screws. When the connecter was removed it allowed the quad to be unlimited or at least governed less and it now can keep up with a friends Baja Dirt Runner 90cc on the road going about what feels like 45mph. (I know it's not going quite THAT fast.)
Old Nov 18, 2007 | 09:35 PM
  #392
oldyeller's Avatar
Default Baja 90cc
I don't know what you were using to record the speed(probably stock speedometer) but there is no way in hell a baja 90 goes 45 mph with or without a rev limiter....On radar I have seen a baja 90 go from about 23-24 mph against the limiter to about 27-28 with the limiter disconnected..........The engine is about the only good point to these quads..Too bad the lousy electrical system prevents it from running most of the time.
Old Nov 18, 2007 | 10:13 PM
  #393
auzburner's Avatar
Default Baja 90cc
This thing flies! You would not believe the speed, def. not 45mph, but it's extremely fast guessing around 35mph, i will clock it by riding next to a car and update with a new reply on the speed of this thing! It's very impressive to me. I will get a YouTube Video up so everyone can see this and how to modify the CDI without voiding the warranty.
Old Nov 19, 2007 | 06:11 PM
  #394
trianom's Avatar
Default Baja 90cc
i have a baja90 atv. its an excellent beginner atv
to make it go faster, i just went to the cdi and unplugged it. i get a much higheer rev and i get about 10 mph faster than with it.
Old Nov 20, 2007 | 10:08 PM
  #395
dand444's Avatar
Default Baja 90cc
I followed your lead on the removal of the metal piece and got and additional 13KM/H. Hitting about 43Km/h now!
Old Nov 21, 2007 | 09:14 AM
  #396
auzburner's Avatar
Default Baja 90cc
Great! I'm glad I could help! Feels like these things go like a bat out of HELL! Lot and Lots of FUN! Oh, and an update on my situation with a broken part: Luckily Pepboys helped me out with the part, but I also called Baja Motorsports about getting a new tie rod end and because the tie rod ends are on back order they sent me a brand new tie rod assembly which contains two tie rod ends and a new tie rod, I amazed at the service based on what others have said in the forums before. Just thought I'd let everyone know.
Old Jan 24, 2008 | 06:53 PM
  #397
stone1098's Avatar
Default Baja 90cc
HEY what local store has the rear brake pads for a baja 90
Old Jan 24, 2008 | 10:55 PM
  #398
Canadian144's Avatar
Default Baja 90cc
I'm pretty sure that local stores don't stock rear break pads, instead you have to call Baja and order it from them.
Old Jan 25, 2008 | 12:53 AM
  #399
Sawyer's Avatar
Default Baja 90cc
<div class="FTQUOTE"><begin quote>Originally posted by: stone1098
HEY what local store has the rear brake pads for a baja 90</end quote></div>
I bought a set for mine off A guy that does warranty work on them. Check with the store you bought it from and ask who does the warranty/service work on them. They may have them in stock. They were cheap like 10 bucks I think.
Ph. Baja if that route doesn't work and if that don't work let us know as that bike is sold under different brand names too.
Old Feb 1, 2008 | 10:00 AM
  #400
prime4145's Avatar
Default Baja 90cc
I have a 05 model and know when you try to start it . It acts like it is in gear . Also with the engine shut off when you try to push the bike backwards it turns the engine over . Has anyone else run into this problem.
