Baja 90cc
Old Sep 8, 2005 | 02:37 PM
  #71
LivingintheOCsucks's Avatar
Default Baja 90cc
so is it better then say a raptor 50 or 80 when it comes to speed?
Old Sep 9, 2005 | 02:29 AM
  #72
Sawyer's Avatar
Default Baja 90cc
Originally posted by: dragoon
Yes I pulled the fuel line offf and yes lts of gas, undid the drain screw on bottom of carb and got nothing
So you got gas to the valve and no fuel in the float bowl. Well like Bozzy said I'd look into the valve. Looks like a few phillips screws and it comes apart there. If its a hard to get at just take the carb right off the quad and onto a work bench or table etc. Who knows you may have some grud stuck in the needle and seat?? To get at that part you have to remove the float bowl on the bottom of the carburator.
Just a note these engines are based or copied from the old Honda engines so something like the Clylmer Honda singles 50-110cc would cover it. I believe Baja has service manuals for them also I heard they once had some available onlline.
Old Sep 9, 2005 | 07:42 AM
  #73
dragoon's Avatar
Default Baja 90cc
Thanks, seems to be working alright for now, would adding a inline fuel filter help with keeping any crud out of the carb???
Old Sep 9, 2005 | 08:38 AM
  #74
ArcticBrat's Avatar
Default Baja 90cc
Yes it would I put an inline feul filter on ours and have not had a problem with the carb. other than these quads are cold blooded and need to warm up to idle good...
Old Sep 9, 2005 | 08:51 AM
  #75
ArcticBrat's Avatar
Default Baja 90cc
My friends son has an 80 raptor and its about the same speed (25 to 30mph) Although with speed-limiter unhooked I can hit 40mph plus with the baja 90cc and I'am 200lbs plus .lol. .....The 80 raptor does have better low end power but then it's also a 3 speed tranny not full auto.
Old Sep 10, 2005 | 04:50 PM
  #76
jef's Avatar
jef
Default Baja 90cc
Does anyone know of an aftermarket muffler such as an FMF that will fit on the baja 90 i think it would help with the bottom end power.
Old Sep 12, 2005 | 08:57 AM
  #77
camster's Avatar
Default Baja 90cc
I found that the fuel line from the gas tank to the carb was too long and could have kinked. That would stop the flow. Also, I cut the wire to the kill switch and soldered the two wires together to complete the circuit. That way there is no chance for it to accidentally come out or be pulled out. I have pulled the plug out of the rev limiter and it runs great at full throttle. I am about 200 lb. and it works great for me. I also have ridden it with my wife on the back. It handles us both, but I don't think I would suggest too much riding like that. I am thinking of changing the rear sprocket to a larger one so it could handle us both, but that would decrease the top speed.
Old Sep 16, 2005 | 02:31 PM
  #78
JerryH's Avatar
Default Baja 90cc
I just purchased the Baja 90cc and have a problem I was hoping someone could help me to resolve.
The ATV will only allow me to go as fast as 30-32km on the speedometer and then the ATV will start to jolt (missing) until I lower the throttle.
I don't know if this would have anything to do with the level of Octane gas being used, but I read later that the ATV requires a Octane of 90 or higher. I had filled mine up with 87 Octane. I haven't had a chance to drain the gas and refill it up with a 90 or higher octane gas yet, but was wondering whether or not this could even be why the ATV is acting this way.
Your thoughts would be greatly appreciated.
My ATV is at the cottage so I haven't had the time to go up there and try the higher octane gas yet.
Old Sep 16, 2005 | 02:53 PM
  #79
DogbertTheConsultant's Avatar
Default Baja 90cc
Hi JerryH,
I haven't had a chance to buy mine yet, hopefully this weekend I will get to CDN TIRE and get a couple for me and the kids, but, if you read through the postings in this forum you will find that there is a rev limiter on the ATV. This is most likely causing the problem. There are at least a couple of posts that will tell you where to find the limiter on the ATV and how to disconnect it. I would try this as well as getting a higher octane fuel and I am sure this will help. I am sure you will get replies from others with hands on experience, I have found everyone to be very helpful in giving me input when requested.
Good luck,
Old Sep 16, 2005 | 02:58 PM
  #80
JerryH's Avatar
Default Baja 90cc
Thanks for the reply, I will look for those posts. I bought the 50cc Dirt Bike as well and I am extremely satisfied with the results.
