redcat-kazuma 50cc wont start
Old 08-14-2005 | 02:28 AM
texaskid's Avatar
Default redcat-kazuma 50cc wont start
my sons 50cc wont start.no spark at the plug.changed cdi box and coil and still no fire.we need help.
Old 08-15-2005 | 11:14 AM
dcombs77's Avatar
Check the rear safety cut off switch. Mine did the same thing. After replacing the plug, coil and stator. and much time on the phone with a tech. I gave up on them and starting testing the wiring system. I cut the wires going to the walk behind safety and reconnected them (without the safety) sure enough it started right up. good luck!
Old 08-17-2005 | 11:19 PM
texaskid's Avatar
thanks for the help.can you tell how to re-wire the rear kill switch im going to try noting esle has worked.
Old 08-19-2005 | 05:07 PM
Donna's Avatar
I seem to have the same problem, changed coil, cdi and no spark, could you please tell me exactly how you rewired it. I followed the wiring up to the ignition switch and did not understand exactly how it worked, Thanks Ken
Old 08-19-2005 | 07:02 PM
spliffy's Avatar
Here ya go Donna:
TO BYPASS ALL CUTOFF SWITCHES ON KMX-50, KMX-110, RFX-110
LOCATE CDI
CUT BLACK WIRE WITH WHITE STRIPE CK. FOR SPARK LEAVING ENOUGH WIRE TO RECONNECT.
THIS WILL RULE OUT ALL CUTOFF SWITCHES ON THE ATV INCLUDING: IGNITION SWITCH, HANDLE BAR SWITCH, SIDE CUTOFF (KMX-50 ONLY) REAR CUTOFF( KMX-50 ONLY)
CDI 5 PIN PLUG WIRING DIAGRAM:
1. GREEN- GROUND
2. YELLOW W/BLACK- IGNITION COIL
3. BLACK W/ WHITE- IGNITION KILL
4. BLUE W/ WHITE- IGNITION PICK-UP COIL
5. RED W/BLACK ? STATOR COIL
Hope it helps, Jim
Old 08-19-2005 | 11:03 PM
Donna's Avatar
Thank you, I will try it Saturday. Donna
Old 08-22-2005 | 10:13 PM
Donna's Avatar
Tried those ideas and even took electrical parts off another 50cc that was running and still could not find the problem, any other ideas would be appreciated. thank you, ken
Old 08-23-2005 | 12:23 AM
texaskid's Avatar
i tried cutting black-white to cdi and still no fire.i have changed kill switch on handle bar and nothing.things we changed---cdi,coil,fuse,switch on handle bar.if anyone has any idea please let me know we need help.
Old 08-23-2005 | 12:46 AM
Donna's Avatar
This is what I have changed and I know these parts are good because I took them off another 50 that was running. coil, cdi, rear safety switch, waist kill switch,fuse, changed ignition switch,changed plug and plug wire.don't seem to be getting any spark to the plug from plug wire but I did not get any from the good 50 either, I am getting spark from the stator just like on the good one but still can not get to start, getting a little disgusted. Ken
Old 08-23-2005 | 11:17 AM
spliffy's Avatar
How are you checking for spark? You should be getting spark if the good 50 runs. Try this if you have a ohm meter, its a link to a trouble shooting page for no spark:
http://www.redcatmotors.com/nospark.asp
I'm afraid this is all the more I can help, sorry.
Quick Reply: redcat-kazuma 50cc wont start
